RingCentral not syncing texts or calls
  • December 13, 2024
  • 54 views
Our ring central extension is not syncing any calls or texts into our CRM Pipedrive. When we click the sync button it just goes gray and doesn’t sync any data. Can you please advise?
Best answer by mlee_closet1
Thanks for the reply! We created a workaround to change the call or text log activity to a different type of activity in pipedrive and then choose to not sync that type of activity back to the calendar. It's a little bit clunky but keeps my calendar much much much cleaner.
View original
  • 254 replies
  • December 18, 2024
@lwallick6 My sincerest apologies for letting this question fall through the cracks and not replying sooner. I will reach out to you in a private message to schedule time with you.
In the meantime, can you expand upon the various things you may have tried in order to get logging to work properly? Are you able to log calls manually? Or, is any kind of logging (manual or automatic) not working?
  • December 18, 2024
I can log a call or text into Pipedrive, but is syncs back to my calendar.  When I delete it off my calendar, the log is removed from Pipedrive.  ?
  • 254 replies
  • December 19, 2024
@mlee_closet1 That is a quirk of Pipedrive. Pipedrive logs activities as calendar events for some reason. It is not something I personally understand from a user perspective, but far be it for me to tell another PM how to design their product.
Who am I kidding? I love telling other product people how to design their products. ;)
Anyways, yes - the behavior you describe is by design. I would reach out to the Pipedrive team to see how they suggest you keep your calendar clear of events you don’t want to see there, while also being able to log activities reliably. Then come back here and tell us what you learn!
  • December 21, 2024
