authorization code flow mode (Embedded widget app) - whether the token refreshed for every Ring central API call or will it refresh after its expiry in 7 days
  • June 24, 2020
  • 311 views
Authorization code flow mode (Embedded widget app) - whether the token refreshes for every Ring central API call or will it refresh only after its expiry in 7 days.
Inorder to enable the same in the Embedded widget app. Is it enough to include the secretkey in env.default file or only in the Iframe render script. Please clarify
