Calls Not Ringing, Results in Missed Calls - RC App
Some users just suddenly started not receiving calls but instead calls are just showing up as missed calls. Uninstalling and reinstalling the app temporarily fixes the issue but it returns within a short time. These same users are also experiencing the issue with their RC apps at home on their laptops (work laptops at home and desktops in the office). They are not set for call forwarding and don't have any after hours set up.
Any suggestions on how to correct this issue? It's been working fine for a few weeks then this started happening this morning.
  • 123 replies
  • September 22, 2023
is it possible they are tweaking some of their settings to avoid work ...
you are saying it is not
-after hours (hope you've checked on all levels - Users, Call queues, Auto-receptionist)
-no forwarding (doesn't sound like it, but still its good to check on all levels)
also you need to check:
- people are not setting themselves to DND
- people are not disabling Call queue calls (if you are using call queues)
- no custom rules, (if you need custom rules, temporarily disable them to rule them out as a cause)
- actual call handling on user level (check app is enabled, ringing for 30sec or longer)
- in the app settings, make sure auto-answer calls is disabled.
We are seeing the same exact thing. The app on a mobile device is working for us, as well as the RC Phone app on a computer. Are you able to test to see if these work for you?
  • August 7, 2024
We are experiencing the same issue with a user on an current model Samsung Galaxy.  We noticed that the Android was not receiving calls in the Ring App (other calls to the cell work fine and Internet access was not an issue).  When we opened the app, it was the latest version from the Google Play store, *BUT* we noticed a green message banner (no screenshot, sorry) that had a message about the App being updated.  It was not asking for us to update the app, rather informing us that it was updated.
Once we ‘cleared’ the green banner, the users phone calls began to appear again on the Android App.
The user never noticed this as they only receive calls on their mobile device and rarely go into the App on their phone.
We experienced the same problem on a second phone (also Android) and we opened the app, cleared the green message banner and that phone also started to accept calls.
It was like the phone-app was disallowing any incoming calls until someone opened it on the phone and clicked that green banner.  Not a good thing if this is going to happen each time the app updates since the users never go into the app :(
  • September 26, 2024
We’re having this issue now as well with the Android app.  The app will show missed calls, but it will not ring as it used to.  I can forward calls to the cell number, but that defeats the purpose of having the app.
 I recommend submitting a Support case for this specific issue. By doing so, our technical team can thoroughly investigate the problem. Please create a ticket at https://support.ringcentral.com/new-case.html.
we have been having a lot of issues. missed calls , if a call is forwarded to my cell I can hear them but they cant hear me.
  • January 4, 2025
Having the same problem. Getting a missed call notification but no phones ring, we get a notification of a missed call and then a voicemail. It happens intermittently, had been happening all day today. Has happened in the past as well. This is going to a call queue. Not sure about single extensions.
Since this seems to be happening intermittently and involves your call queue, it would be best to submit a support ticket so our team can investigate further.
Please provide as much detail as possible, including:
  • The specific call queue(s) affected.
  • The timeframes when the issue occurred.
  • Any patterns you’ve noticed (e.g., certain callers or extensions involved).
You can submit a ticket via the RingCentral Support Portal or contact our support team directly for assistance.
  • June 18, 2025
We are having similar issues, have been for a few months now, but it has been worse last few weeks. We have worked with RC and tech support and so far nothing has worked. We have a call tree that dials cell phones sequentially, however each one shows :01 and it never rings, there is no missed call - some times it shows as “missed” and sometimes it shows “accepted”, but we never get the call or know it was missed.
We have T-Mobile cell phones and I contacted T-Mobile. We now have a cell booster IN OUR OFFICES and we have full 5 bars of cell signal, so it’s back on RC it seems. T-Mobile also “reset” our phones for their end to refresh to appropriate towers.
I have tried everything else I have found and/or read and/or suggested by RC (or Google). We use the Desktop App to set up our account, greetings, etc., then build our call tree for our in-bound numbers.
If ANYONE has had any success, please share!!!
Likewise, If anyone has good alternatives to RC, please send them as well. We have been here for 8 years, but if we can’t get calls, WE HAVE TO MOVE TO ANOTHER PROVIDER.
  • June 27, 2025
I am also having this issue with my end users. This is with the iOS app. Would love any updates on solutions.
