Avaya j169 Desk Phone- Feature code to remove DND from deskphone
Does anybody know the feature code to turn off DND on a Avaya j169 Deskphone. Tried going through the menu then to features and i can see the DND but no options. When you try to use the select button it does nothing.
Hi! Have you tried the instructions found on this link?
https://www.manualslib.com/manual/1685980/Avaya-J169.html?page=71
View original
yes....Select button does nothing
