Avg Speed of Answer
  • April 22, 2024
  • 151 views
I need to include the average speed of answer in the Power BI Dashboard, and I'm using the Analytics API to pull data. Could you provide me with the formula for calculating the average speed of answer?
  • April 24, 2024
Can you set and check the callSegmentsDuration result.
