C#: Resource for parameter [accountId] is not found
  • August 7, 2020
  • 1582 views
I'm working on a sandbox account, trying to use the Get Extensions API. My code is as follows:
using System;
using System.Threading.Tasks;
using RingCentral;
namespace Send_SMS
    class Program
        const string RINGCENTRAL_CLIENTID = "<sandbox-id>";
        const string RINGCENTRAL_CLIENTSECRET = "<sandbox-secret>";
        const string RINGCENTRAL_USERNAME = "<sandbox-username>";
        const string RINGCENTRAL_PASSWORD = "<sandbox-password>";
        const string RINGCENTRAL_EXTENSION = "101";
        const string RINGCENTRAL_PRESENCE_USER = "<sandbox-username>";
        const string RINGCENTRAL_PRESENCE_EXT = "101";
        static RestClient restClient;
            restClient = new RestClient(RINGCENTRAL_CLIENTID, RINGCENTRAL_CLIENTSECRET, false);
            restClient.Authorize(RINGCENTRAL_USERNAME, RINGCENTRAL_EXTENSION, RINGCENTRAL_PASSWORD).Wait();
            get_presence().Wait();
        static private async Task get_presence()
            var response = await restClient.Restapi().Account(RINGCENTRAL_PRESENCE_USER).Extension().List(listExtensionsParameters);
            Console.WriteLine("Extension for Test Account: " + response);
Where anything in <> is taken from the https://developers.ringcentral.com/my-account.html#/application-credentials site.
I was able to do the Send_SMS tutorial successfully, but for this, I'm getting:
Content: {
"errorCode" : "InvalidParameter",
"message" : "Resource for parameter [accountId] is not found",
"errors" : [ {
"errorCode" : "CMN-102",
"parameterName" : "accountId"
What am I missing here?
Best answer by Caleb317185022
Is this the correct AccountId to use?
When I click your link, I get:
{  "errorCode" : "AGW-404",  "message" : "Resource not found",  "errors" : [ ] }
Maybe the account number you are providing might not actually belong to the Organization or the account itself.
Check the account number and provide the correct number or '~' ( tilde ) should work for the logged-in user.
You can use https://platform.devtest.ringcentral.com/restapi/v1.0/account/~ to get your account id number
  • August 7, 2020
