Facing Issue in Auth2.0 PKCE
  • May 17, 2022
  • 451 views
We are performing Auth2.0 PKCE for authorization purposes. As per the documentation following all the processes.
1. Generate Verify and challenge for PKCE
2. User login and consent
The above two processes are done, successfully.
When we are performing
3. Exchange auth code for an access token
The error we are getting is :
  "error": "invalid_client",
  "errors": [
      "errorCode": "OAU-123",
      "message": "Client authentication is required"
  "error_description": "Client authentication is required"
//Pasting my return URI Code Below, Please let me know what we need to do in order to resolve the issue
It's a PHP code,
<?php
$code = $_REQUEST['code'];
$state = $_REQUEST['state'];
if ($code)
    $ch = curl_init();
    curl_setopt($ch, CURLOPT_URL, "https://platform.devtest.ringcentral.com/restapi/oauth/token");
    curl_setopt($ch, CURLOPT_POST, 1);
    curl_setopt($ch, CURLOPT_POSTFIELDS, "code=$code&grant_type=authorization_code&client_id=<client-id>&code_verifier=LQCmsfhneP9_R2jQ85En9RO--ohyrIKmej3rpocjjaE&redirect_uri=https://my.callback/listener_ringcentral.php");
    curl_setopt($ch, CURLOPT_HTTPHEADER, array(
        'Content-Type: application/x-www-form-urlencoded'
    curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
    try
        $server_output = curl_exec($ch);
    catch(Exception $e)
        echo '<pre>';
        print_r($e->getMessage());
    curl_close($ch);
    // Further processing ...
    echo '<pre>';
    print_r($server_output);
    if ($server_output == "OK")
        echo '<pre>';
    else
        echo 'Failed CURLLLLL';
  • May 24, 2022
Hi @Nitin Singh, If you are able to able to perform the 1st two steps as mentioned and are only stuck on Step 3, then please refer to this guide to understand how to create the request for the same. Make sure your Authorization Header is base 64 encoded string for Client ID and Secret in the correct format.
Also, consider using the RingCentral's PHP SDK which might make the job easier for you, and tutorial you might find helpful.
  • May 28, 2022
@Nitin Singh So I put together a better PHP PKCE example for you. I will let the code speak for itself and assume you can follow along reasonably well. I will be adding this to the documentation soon, providing a lot more detail and example code around using PKCE auth. https://gist.github.com/byrnereese/a52cc4e473f76b8a23c8e517d8237d7d
  • May 28, 2022
I provided a complete end-to-end working example of PKCE auth in PHP below. I am trying to ascertain what you did wrong though. It is difficult without seeing how the code challenge and verifier were generated. They are derived from each other. One challenge I had was persisting the code verifier through the asynchronous auth process. Can you share your full code sample?
