Issues with ringcentral-chatbot package
  • March 29, 2021
  • 120 views
I am using the node ringcentral-chatbot package along with the ringcentral. I am using the ringcentral-chatbot package to subscribe to and receive webooks, and I am currently getting an exception in the ringcentral-chatbot package when I receive the following webhook
WebHook payload: {"uuid":"2249990457863490969","event":"/restapi/v1.0/glip/posts","timestamp":"2021-03-29T22:49:33.826Z","subscriptionId":"fb6f0643-0eb4-4996-b4dd-96dcecc9181b","ownerId":"292777004","body":{"id":"4790575108","groupId":"616022018","type":"TextMessage","text":"good","creatorId":"292005004","addedPersonIds":null,"creationTime":"2021-03-29T22:49:33.509Z","lastModifiedTime":"2021-03-29T22:49:33.509Z","attachments":null,"activity":null,"title":null,"iconUri":null,"iconEmoji":null,"mentions":null,"eventType":"PostAdded"}}
POST /bot/webhook 200 0 - 0.650 ms
/home/ec2-user/my-bot/node_modules/ringcentral-chatbot/dist/handlers/postAdded.js:30
const group = await bot.getGroup(groupId);
TypeError: Cannot read property 'getGroup' of null
at postAdded (/home/ec2-user/my-bot/node_modules/ringcentral-chatbot/dist/handlers/postAdded.js:30:27)
at async /home/ec2-user/my-bot/node_modules/ringcentral-chatbot/dist/apps/bot.js:52:28
Any ideas on what might be causing this?
I have the following defined as environment variables
RINGCENTRAL_SERVER
RINGCENTRAL_CHATBOT_ADMIN_USERNAME
RINGCENTRAL_CHATBOT_ADMIN_PASSWORD
RINGCENTRAL_CHATBOT_EXPRESS_PORT
RINGCENTRAL_CHATBOT_CLIENT_ID
RINGCENTRAL_CHATBOT_CLIENT_SECRET
RINGCENTRAL_CHATBOT_SERVER
RINGCENTRAL_APP_REDIRECT_URL
RINGCENTRAL_CHATBOT_DATABASE_CONNECTION_URI
RINGCENTRAL_CHATBOT_AUTH_CODE
I am also using the following code for authentication
const rcsdk = new SDK({
    server: SDK.server.sandbox,
    appKey: process.env.RINGCENTRAL_CHATBOT_CLIENT_ID,
    appSecret: process.env.RINGCENTRAL_CHATBOT_CLIENT_SECRET
const platform = rcsdk.platform();
let data = platform.auth().data();
data.token_type = "bearer"
data.expires_in = 1000000
data.access_token = process.env.RINGCENTRAL_CHATBOT_AUTH_CODE
data.refresh_token = 'xxx'
data.refresh_token_expires_in = 1000000
platform.auth().setData(data)
I also setup
If you use the chatbot framework, why do you need to write code to do authentication? The framework handles it for you.
I think there is no data in your database, so the bot is null:
https://github.com/ringcentral/ringcentral-chatbot-js/blob/master/src/handlers/postAdded.js#L16
It seems that you are trying the bot on a EC2 server. Does it work on your dev server? Maybe you can try remove and re-add the bot, if the bot doesn't exist in your db.
