Testing fax without real fax machine
  • June 23, 2020
  • 2089 views
How can we test fax if we don't have a remote fax machine?
Do we always need a physical fax machine to test the fax everytime? Or there is some way to test fax as demo?
Best answer by Anirban2396911020
If you check this:
https://stackoverflow.com/questions/49864445/how-to-test-ringcentral-fax-api-without-sending-to-real-fax-machine
seems that the solution mentioned there is to create two sandbox fax numbers and send from one number to the other. Since, sandbox account provides multiple numbers, this seems too be a good way to test the fax and also receive the fax without using real number or machine device.
View original
If you check this:
