Fun with Text to Speech
  • July 23, 2024
  • 561 views
We utilize the text-to-speech engine for a couple of our IVRs, and generally it works quite well.
However, on one IVR I’m having a rough time getting it to say “dental” properly. I’ve tried all sorts of phonetics and just about the time I get close the tts engine spins into something completely different.
Also, does it need to go so fast? I use three commas between every sentence just to put a normal amount of space between them. I’d think it would understand a period means to pause a sec, but no.
Problem Solver
  • 153 replies
  • July 23, 2024
I’d recommend you use something like
https://www.narakeet.com/app/text-to-audio
sounds more natural than the TTS RC uses, unless they’ve made improvements to it.
The good thing about narakeet is that it’s free and no registration needed.
There is a limit on how many recordings you can make, but you can easily bypass it.
-Imagine you’ve decided to use narakeet but you’ve used up all free audio recordings you get to download.
-you can actually still make recordings, you just can’t download them
-to get unlimited downloads
  1. press F12 to open DevTools
  2. Go to Network > Media
  3. use narakeet to generate text to speech audio as usual.
you’ll be able to download the mp3 from the DevTools section
Pic 1 before clicking on “Create Audio”
Pic2 after creating an audio I can download it from devtools regardless if I have a free download or not. Right click and open in new tab in order to do so.
You can use this trick with any TTS software and with any media (audio/video files)
