Is it possible to activate integrated calling on an Android phone?
  • December 2, 2020
  • 1291 views
I'm a new Ring Central user and just discovered that when I'm on a RingCentral call (using the mobile app) and a call comes into my direct cell phone number it automatically puts the RingCentral call on hold.
This is obviously very annoying and disruptive. Is there a solution? I'm using a Google Pixel 4
"RingCentral calls will be interrupted by incoming mobile calls when Integrated Calling is disabled. "
Check here how to manage integrated calling:
https://support.ringcentral.com/article/10693-RingCentral-Phone-Mobile-App-Managing-Integrated-Calling.html
and here
  • December 3, 2020
That article shows an app that looks different from the one we're using. There is no option for activating integrated calling on Android or iOS.
  • December 22, 2020
The attached screenshot shows what options I've got when I scroll to the bottom as you suggest. There is no option for turning on integrated calling. So far I'm really not enjoying the RingCentral mobile app!Screenshot_20201222-103429.png
