Is it possible to have a strobe light ringer attached to a polycom handset?
  • February 4, 2022
  • 1022 views
We'd like to add a stobe light ringer to a polycom phone. Our environment is loud and sometimes it's impossible to hear the phone ring.
@Victor Meyerhoff you may need to reach out to Polycom Support for this question.
View original
  • February 4, 2022
Thank you
  • February 8, 2022
Poly and Algo both make solutions for this:
https://www.poly.com/ca/en/products/headsets/accessories/status-indicator
https://www.algosolutions.com/product/2506-polycom-vvx-ring-detector/
The Algo solution requires Algo SIP speakers and utilizing the speaker's relay so that incoming calls ring via the overhead PA.
But honestly, your best bet likely is just to buy a SIP speaker (like an Algo 8180: https://www.algosolutions.com/product/8180-sip-audio-alerter/), register it as a device in RingCentral, power it via PoE, and add it to ring simultaneously with your loud shop/environment phone(s).
  • February 9, 2022
Thanks!!!
