why does ringcentral put Teams meetings on hold?
  • August 12, 2021
  • 1235 views
One of our users is providing remote training over MS Teams, sharing her screen and sound.
She goes to make a call but as soon as Ring Central connects the call, the attendees in the meeting are put on Hold.
Although this only seems to be happening for 1 user so far, other users can perform this action fine.
Since, this happened with 1 user while remaining worked fine, can you please create a support case here. The support team can assist you and troubleshoot the issue with the particular user.
  • 5 replies
  • August 12, 2021
It is most likely a resource issue. One Microphone, one camera can be used by one app at a time. If the presenter has Teams running first, then Teams has the microphone and the camera in use. In order for Ringcentral to do its meeting it needs to take control of the microphone and the camera so it puts Teams on hold.
If you have two microphones and cameras on one computer, then you could "assign" a specific pair of mic and camera to Teams and assign the other pair to RingCentral. The problem is that this may not work well because of IRQ issue and one or other may not work or be choppy.
Besides installing more hardware as in a second camera and microphone; the easiest solution is to start RingCentral on your presenters computer. Then on a second computer launch Teams. Then from the RingCentral computer remote desktop into the Teams computer. This will bring up the Teams computer as a window on the presenters RingCentral computer. That way there would be no conflict of which app will control the microphone and camera.
