Phantom Missed Calls
  • September 22, 2023
  • 373 views
There are three users experiencing the same issue. When an incoming call comes in, whether
it’s to the direct user number or the IVR, the call does not display a notification that allows that
user to answer the call. Nonetheless, the call shows as a missed call and shows up in the call log as such.
I have tried a number of troubleshooting solutions that have not worked. I told the users to
uninstall and reinstall the app on their desktop, I have tried deleting their user and recreating
their user with the same settings, I have gone through their computer and RingCentral app
settings to ensure notifications are enabled, I have cleared the cookies and cache, but nothing
has solved the issue.
Each are on their desktop and they are either
using the desktop app or the web app.
  • November 14, 2023
Hi Michael, I'm afraid I don't have a solution to this but I just want to chime in to say multiple members on my team are having the same issue.
One person has noted that the phantom calls indicate that she is receiving a fax to her direct line, but no one else has made this observation.
