Cannot connect to RC api using powershell
Cannot connect to API using my powershell script. It looks like it connects but then when it starts running through the AD portion of my script it errors out with this error:
t C:PSAutomationsRCUpdateInfoV3-test.ps1:36 char:17
+ ... $userinfo = Get-ADUser -Filter "UserPrincipalName -eq '$email'" -prop ...
    + CategoryInfo          : NotSpecified: (:) [Get-ADUser], ADException
    + FullyQualifiedErrorId : ActiveDirectoryServer:8254,Microsoft.ActiveDirectory.Management.Commands.GetADUser
Invoke-RestMethod : {
  "message": "Need Content-Type header"
Full Script:
$RC_SERVER_URL="https://platform.ringcentral.com"
$RC_CLIENT_ID="Yxxxxxx"
$RC_CLIENT_SECRET="xxxxxx"
$RC_JWT_TOKEN = "xxxxxxxx"
$headers = @{
    ContentType = 'application/x-www-form-urlencoded; charset=UTF-8'
    Accept = 'application/json'
    Authorization = 'Basic ' + [Convert]::ToBase64String([Text.Encoding]::UTF8.GetBytes("${RC_CLIENT_ID}:${RC_CLIENT_SECRET}"))
# RC authenticate and obtain access token
$response = Invoke-RestMethod -Method POST -Uri ($RC_SERVER_URL + "/restapi/oauth/token") -Headers $headers -Body @{
    grant_type = 'urn:ietf:params:oauth:grant-type:jwt-bearer'
    assertion = $RC_JWT_TOKEN
# Extyract Access Token
$access_token = $response.access_token
# Fetch User info from RC api
$AllUsers = Invoke-RestMethod ($RC_SERVER_URL + "/restapi/v1.0/account/~/extension/?perPage=1000") -Headers @{
    Authorization = "Bearer $access_token"
} -Method Get
# Array to store users with AD information
$UsersArray = @()
#import AD Module
Import-Module ActiveDirectory
# Iterating over user records
foreach ($id in $AllUsers.records) {
    $email = $id.contact.email
    # Retrieving AD user information using email
    $userinfo = Get-ADUser -Filter "UserPrincipalName -eq '$email'" -properties department, title
    $emailCheck = $userinfo.UserPrincipalName
    if ($emailcheck -ne $null -and $id.type -ne "Department") {
        $department = $userinfo.department
        $jobtitle = $userinfo.title
        $UsersArray += @(
                id = $id.id
                department = $department
                jobtitle = $jobtitle
# Iterating over users and updating profiles
foreach ($user in $UsersArray) {
    $did = $user.id
    $putbody = '{"contact": {"jobTitle":"' + $user.jobtitle + '"}}'
    Invoke-RestMethod ($RC_SERVER_URL + "/restapi/v1.0/account/~/extension/$did") -Headers @{
        ContentType = 'application/json'  # Add Content-Type header
    } -Method PUT -Body $putbody
    $putdepartment = '{"contact": {"department":"' + $user.department + '"}}'
    } -Method PUT -Body $putdepartment
    Start-Sleep -Seconds 3
    $did = $null
  • 2423 replies
  • March 25, 2024
Try add the Content-Type and the Accept headers to each API request.
    Content-Type = "application/json"
    Accept = "application/json"
} -Method Get
  • March 25, 2024
Still getting same error after changing the code
below is an excerpt from the code with the changes you suggested.
    "Content-Type" = "application/json"
    "Accept" = "application/json"
    "Authorization" = "Bearer $access_token"
} -Method Get
