How many external numbers can I forward calls from an Extension?
  • December 23, 2021
  • 1152 views
From an extension, in the Call Forwarding and Voicemail | Work Hours rules, I am attempting to forward a call to multiple external "Numbers" (not "Coworkers"). I have it set to "Ring all at once" and have 5 numbers listed. These numbers are cell phones.
The recipients report that only two of them are getting the calls forwarded to them. 3 are not getting calls at all. Is there a limit set to external numbers to receive forwarded calls from a single extension? If so, what is that limit. Is this documented anywhere?
  • December 27, 2021
I don't know how many (there is no documentation, and the service web just lets you click to add more number), but there must be some limit. However, I don't think that it is 5 numbers. If you remove the 2 numbers which got the forwarded call, did the other 2 or 3 numbers got ringing?
  • December 28, 2021
Please refer to the article here: https://support.ringcentral.com/article/Calls-Not-Forwarding-RingCentral-to-Third-party-Phone-Numbers.html
You should be able to forward calls to more than 3 numbers (do not know the exact limit) as well via Call Forwarding and answering rule settings.
If you still have issues , please reach out to RingCentral Tech Support team for these queries : https://support.ringcentral.com
  • December 29, 2021
Thank you both. Will test via removal of the two that worked. Will also play with the number of rings for each remote number.
