[PYTHON] Timeout with websockets ConnectionClosedError: received 4300 (private use) Idle timeout expired; then sent 4300 (private use) Idle timeout expired
  • July 14, 2023
  • 270 views
Trying to setup a heartbeat to keep the Notification websocket listener app that I am developing from crashing...
I am subscribing for session events and processing them in python just after time the app will fail with the above message.
I wonder what is the best way to do this... platform.refresh?
should I re-recreate the subscription on timeout vs sending a ping?
heartbeat_interval = 30  # in seconds
async def heartbeat(platform, interval):
    while True:
        try:
            platform.refresh()
        except ConnectionClosed:
            break
        await asyncio.sleep(interval)
To keep it alive, you should send a websocket ping frame. This is just a low level websocket exception that has little do to with RingCentral. (RingCentral SDK should handle this case though).
Here is how JavaScript handle it, FYI: https://github.com/ringcentral/ringcentral-extensible/blob/master/packages/extensions/ws/src/index.ts#L265
