staying authenticated on multiple extensions in python to avoid rate limits
  • October 11, 2019
  • 1320 views
I'm trying to make create an internal data warehouse that collects every one of our user's call data on a nightly basis. My initial attempt took an absurd amount of time as I had to throttle the rate of API calls to avoid rate limits. I contacted dev support and was told I could make multiple API calls without encountering limits by staying authenticated on multiple extensions. I'm not sure how to stay authenticated on multiple extensions in python... using the python ringcentral module requires logging in with a username and pw, is there any way around this?
Best answer by PhongVu
To read all users' call data on a single API call, you can login (authenticate) your app with a super admin user (e.g. the default 101 extension), then read the call log at the account level (see the reference)
Now, if you need to login every time you call an API, you can implement the authentication this way:
from ringcentral import SDK
import json
from os import path
rcsdk = SDK( RINGCENTRAL_CLIENTID, RINGCENTRAL_CLIENTSECRET, RINGCENTRAL_SERVER)
platform = rcsdk.platform()
def login():
    res = platform.login(RINGCENTRAL_USERNAME, RINGCENTRAL_EXTENSION, RINGCENTRAL_PASSWORD)
    file = open("access-tokens.json",'w')
    file.write(res.text())
    file.close()
    read_calllog()
def read_calllog():
    file = open("access-tokens.json",'r')
    tokens = file.read()
    platform.auth().set_data(json.loads(tokens))
    if platform.logged_in() == False:
        print ("token expired. Relogin")
        login()
    else:
        params = {
            'dateFrom': "2019-01-01T00:00:00.000Z",
            'type': ['Voice'],
            'direction': ['Outbound']
        resp = platform.get('/restapi/v1.0/account/~/call-log', params)
        for record in resp.json().records:
            print "Call type: " + record.type
if path.exists("access-tokens.json"):
    print("has token")
    read_calllog()
else:
    print ("must login")
    login()
View original
  • 2314 replies
  • October 11, 2019
import json
from os import path
def login():
    file.close()
    read_calllog()
def read_calllog():
        login()
    else:
        params = {
            'type': ['Voice'],
    print("has token")
    read_calllog()
else:
    login()
  • December 3, 2019
Thanks so much for your help @Phong Vu. If anyone is interested in an alternative solution, you can generate access tokens for multiple users, store these tokens in a database and use the tokens to make multiple simultaneous calls. That method worked beautifully for me. Hope it helps!
