Vtiger Integration
Within my CRM which is called Vtiger there is built in PBXManager.
It requires some information to connect
I would like to integrate this to streamline my workflow.
Anyone have any ideas on how I may manage this?
Thank You for your time.
J. Thomas
jthomas@newdesignsmedia.com
  • March 8, 2016
I'm using the same CRM. If you get an answer for this I'd like to know too.
Quick update...
I've been asking around for the right data to complete this, once we hear something we'll get it posted here.
  • Known Participant
  • 125 replies
  • March 10, 2016
I don't suspect you will get anywhere with that since it is specific for Asterisk integration.  What do you want to accomplish though?  You may be able to screen pop customer records with caller ID using the desktop app easily.
Yes, after some research, the screenshot you've provided only contains information for integrating with a specific provider (Asterisk) which doesn't apply to RingCentral.
  • March 14, 2016
Yeah ive been looking at that now comparing my luck with platform called Odoo
  • January 17, 2017
This reply was created from a merged topic originally titled VTiger CRM Integration?. Folks. I am looking at possibility of integrating ring central gateway with a CRM app called VTiger.  Are you aware of anyone having configured a solution to integrate with Vtiger's API?
  • January 18, 2017
First, thank you Mike at Ring Central, for moving my question into this string.   Very well done.  Tells me you guys are really paying attention.
Second, it seems that there is no way to integrate ring central with vtiger at this point?   I'm a business owner looking for plug and play solutions.  Don't have capital in my very small business, for technology staff and don't have time to address myself.  I could patch a working solution together but it appears not to exist, right?  IE, no existing dialogue boxes or menus to ling vtiger and Ring Central?
Are you aware of apps built to link these tools?  (ring central and vtiger).
Thank you again.
  • 11 replies
  • May 8, 2018
Hey, Keith! Was wondering if you've found the right solution for your query. With the way things are going, there are lots of 3rd party tool available out there that could help you integrate Vtiger with Ring Central but haven't got a clue which one is right for you since we're using a different CRM. Hope you've managed to find what you're looking for, though.
Take a look at zoho crm and its out of the box integration with Ring Central, it not only gives you a call button, but logs all of your inbound and outbound calls automatically.
