Zoho CRM Ring Central Plugin Call handling
  • December 13, 2024
  • 59 views
Hey Community and Developers.
Why doesn’t Zoho’s RingCentral integration allow users to hang up calls directly within the Zoho CRM plugin? It seems users currently need to end calls separately using the RingCentral app. Is there a workaround or setting that enables this functionality?
From my research, it appears the integration relies on the RingCentral API for call handling, which might limit certain features in the plugin. However, the available API documentation doesn’t provide enough detail to confirm this fully. One alternative I’m exploring is switching to the browser call handling method, which seems to offer full control over calls.
While this alternative is functional, implementing it would require time and resources to train users and update workflows. If there’s a clear and definitive answer regarding this issue, it would help me make an informed decision on the best course of action.
Thanks in advance for your insights!
georgelu
  • 18 replies
  • December 16, 2024
Hi Alvy,
Thank you for your post on the community portal! While RingCentral provides APIs for developers and partners to build integrations, it's important to note that not all integrations are directly managed by our team. The current Zoho-RingCentral integration was developed and is maintained by Zoho. For questions, feature requests, or specific use cases like call handling within the plugin, I recommend reaching out to Zoho's support team. They will be best positioned to address your needs or explore potential updates to the integration.
https://www.ringcentral.com/apps/zoho-crm
