Handling sms sending failed
  • September 11, 2020
  • 860 views
When sms are send, we can sometimes see the message status as failed or sending failed.
How can the api be used to send the same message again when it fails.
I don't see any option or parameters in send sms api for resending the message again. How to configure that in the api?
Best answer by Anirban2396911020
As per reference here: https://community.ringcentral.com/questions/10444/how-is-resending-sms-handled.html
"The system will automatically resent for 3 times. " which means SMS API is capable enough of resending the message upto 3 times incase of any failure
View original
