Missing required creator property 'schemas' (index 0)
  • September 13, 2018
  • 1250 views
Exception: 400 Bad Request (and additional error happened during JSON parse: Response is not JSON)
SDK HTTP Error at https://platform.devtest.ringcentral.com/scim/v2/Users/244580004  Response text: Missing required creator property 'schemas' (index 0)   at [Source: org.glassfish.jersey.message.internal.ReaderInterceptorExecutor$UnCloseableInputStream@16cb921a; line: 1, column: 309]  Previous: Response has unsuccessful status
$response = $platform
->put('https://platform.devtest.ringcentral.com/scim/v2/Users/244580004', array(
"userName" => "nibu.eapen@test.com",
"name" => array(
   "familyName" => "Doe",
   "givenName" => "Jeremy"
"active" => 1,
"emails" => array( 0 => array(
"value" => "nibu.eapen@test.com",
"type" => "work")
"addresses" => array( 0 => array(
"streetAddress" => "900 Main St",
"locality" => "Belmont",
"region" => "CA",
"postalCode" => "94002",
"country" => "United States",
"type" => "work")
For SCIM API call, the schemas needs to be specified in the payload. Please add the following to the API call, it will resolve the 400 error.
"schemas" : [ "urn:ietf:params:scim:schemas:core:2.0:User" ],
