Receiving "unauthorized_client" error when using php curl for auth/token
  • January 16, 2019
  • 4157 views
  "error" : "unauthorized_client",
  "error_description" : "Unauthorized for this grant type",
  "errors" : [ {
    "errorCode" : "OAU-251",
    "message" : "Unauthorized for this grant type"
Here is my code below:-
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL, "https://platform.devtest.ringcentral.com/restapi/oauth/token");
curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
curl_setopt($ch, CURLOPT_POSTFIELDS, "username=+12048184079&password=Reset321$$&extension=101&grant_type=password");
curl_setopt($ch, CURLOPT_POST, 1);
curl_setopt($ch, CURLOPT_USERPWD, "1RjNgM-LTxxxxxFuE-ggrHA" . ":" . "524fjcxxxxxxxxxxCPclIZHxxxxxx_FdfegzA");
$headers = array();
$headers[] = "Accept: application/json";
$headers[] = "Content-Type: application/x-www-form-urlencoded";
curl_setopt($ch, CURLOPT_HTTPHEADER, $headers);
$result = curl_exec($ch);
echo '<pre>'; print_r($result); die;
if (curl_errno($ch)) {
echo 'Error:' . curl_error($ch);
curl_close ($ch);
  • January 16, 2019
Hi Andrew,
The following grant types are available for your application:
* Authorization Code
* Refresh Access Token
Please find instructions on how to use these flows:
https://developers.ringcentral.com/api-reference#OAuth-2-0
https://ringcentral-api-docs.readthedocs.io/en/latest/oauth/#authorization-flows
Thanks,
Igor
  • January 16, 2019
can you correct my code or give me the exact code according to my php curl for this error
The screenshot shared by you seems you have created application of platform type server/ web which supports grant_type=Authorization code while you are trying grant_type=password.
You need to create application that support grant_type,=password or password flow in ring central terms
