RingCentral not reachable for Fax - Recurrences are increasing
  • October 10, 2019
  • 1302 views
We are facing issues related to RC not being available for Fax API.
Following is one example:
Response: StatusCode: 404, ReasonPhrase: 'Not Found', Version: 1.1, Content: System.Net.Http.StreamContent, Headers: { Connection: keep-alive RCRequestId: a02bf940-ea3d-11e9-9b97-005056afc229 RoutingKey: SJC01P13PAS07 X-Rate-Limit-Group: medi
Here is another one:
The remote host closed the connection. The error code is 0x80070057.
What is going on with this issue? Please connect immediately.
  • October 10, 2019
I see that you have some successful fax API calls in the last 7 days. Isn't that you could send some faxes successfully?
I only see a few 404 responses from the get message-store and get content API calls. Can you double check to confirm this.
