Ringout integration issue
  • February 11, 2019
  • 2670 views
Hi everyone , I'm the begininer. I'm trying to integrate the ringcentral for my website to make calls to my customers when I onclick on their name. Can anyone send me the code how to integrate the app ?
  • February 11, 2019
I am not sure if you really want to use the ring out feature. But as you described, I think click to dial is the goal you want to achieve. So do check out these possibilities and let me know if you have questions:
1. https://github.com/ringcentral-tutorials/ringcentral-widgets-demo
2. https://github.com/ringcentral-tutorials/ringcentral-embeddable-demos
Or check if using the WebRTC could be what you need.
2. https://github.com/ringcentral-tutorials/getting-started-with-webrtc-js-demo
If you want to use just ring out feature, please read this tutorial https://ringcentral-api-docs.readthedocs.io/en/latest/calls_ringout/
Hope this helps!
+ Phong
  • February 12, 2019
Thanks Phong for your valuable solution. Now the Ringout is working from the sandbox account.
