philips7591 avatar image
philips7591 asked philips7591 commented
Incoming phone calls are not creating tickets in Zendesk
We've been working with RingCentral for a little over 3 months. RingCentral has never created a new Zendesk ticket when an incoming call is received. I've gone through every article on Zendesk and RingCentral that I can find, with no result. Has anyone else had this issue? How do I solve?
getting started
1 |3000
bjsvec avatar image
bjsvec answered bjsvec commented
I haven't played with this for a while because it turned out to not be as useful as I hoped.  We don't have good records of phone numbers as much as email addresses here and many callers have multiple, different numbers they call us from.  Anyhow, I recall it was important to format the phone numbers in Zendesk correctly.  I'll test again and see if I can give you more specifics, but try things like 5105551212 or +15105551212, etc.
1 comment
1 |3000
I just tested and it works for me as long as the phone number for the user in Zendesk is entered as 15105551212 format.  It auto opens a new ticket, creates a private note with time stamp and a new private note window also.
0 Likes 0 ·
philips7591 answered philips7591 commented
Brandon,
Thank you for your response, it's really helpful. What do we do if it is a new customer with no phone number in the system?
5 comments
1 |3000
I just tested that too and it opens a new ticket with no other info than a phone number form the caller ID.  You would have to add the details like name, email, and organization as needed, I guess.  Then next time it should pop the correct customer and organization if they call from the same number again.
0 Likes 0 ·
Unfortunately, that's not working for us. When we answer a call in Zendesk on the RingCentral widget, the call is moved to our RingCentral Mac desktop and no ticket is created. So frustrating! Thanks for your help though, I appreciate it.
0 Likes 0 ·
Hmm. I was answering my test calls on my desk phone, but also have the Mac desktop app running.  I actually didn't know you could answer in the widget.  I will try that and see if anything different happens.  Have you tried answering via the desktop app first instead of the Zendesk widget?
0 Likes 0 ·
Weird.  I can't see any way to answer with the widget.  the ticket only gets created or popped after I answer the call on my desk phone or desktop app.
Are you using the voice integration ZD has?  Mabe that is interfering?
0 Likes 0 ·
Not using any voice integration from Zendesk. Even when we answer from our RingCentral from the Mac Desktop, tickets aren't created. Not sure why I would consider continuing to pay for the service if one of their product promises doesn't work for us.
0 Likes 0 ·
Developer sandbox tools
