AI Receptionist Knowledge Base Uses and Limitations?
  • April 11, 2025
  • 6 replies
  • 1099 views
Want to get my receptionist in production. What would help for all of us:
  1. A sandbox to test what we’re building, not at the individual stage level, but in basically a production level sandbox.
  2. The 500 character “prompt” (ie, company description) is way too short. It also may be better used as a traditional system prompt rather than an faq generating action (“You are a helpful knowledgeable and kind assistant for company XYZ… Always use {variables}. Never say {variable}. Do not insert stock phrases like “would you like me to transfer you to X”. Trying to build a capable assistant not a switchboard.
  3. Please provide more information on the knowledge base usage, and how the AI references it.
    we can create (some of us have this handy) our own faq; can the knowledge base contain instructions on bot behavior…tone/temperature etc? (More than the options for the default voice and style)?
  4. Will growing knowledge bases create significant latency in the AI response?
  5. are .md or .xml files usable in this feature? Those seem to be the standard with many agentic systems (as well as the current RC IVR config file format).
  6. Are key value pair (FAQ for example ) lists better in a csv file or a text/pdf file?
  7. An off ramp for non English callers. There has to be a way for the agent to recognize non-English, and have its own path.
  8. What benefits/limitations exist if the knowledge base contained a list of URL’s (that basically link to another knowledge base that relates to this one? Can the current version of AiR perform a real time web search like openAI, Gemini and Perplexity?
  9. it would be helpful to know the underlying infrastructure of the RC AI build.
I can go on.. but if anyone out there has any answers advice or creative workarounds, would love to hear them!
Love this! Let me share this with our AI Assistant team for feedback!
I want to give clear INSTRUCTIONS to AIR. Like:
If …… then do …………
Specially:
If a conversations takes more than 5 minutes, transfer the call to a live agent.
How do I do it?
myobgynThe First StepAuthor
If …… then do …………
Specially:
How do I do it?
Six months since this feature launched and we don’t have basic fundamental prompting capabilities for a true voice AI receptionist
Hi everyone! I’ve shared this entire thread with our AI Assistant team so they can take a closer look at your specific requests.
In the meantime, please keep the feedback coming! The more detailed use cases you provide, the more it helps our product team prioritize improvements.
Thanks again for sparking such a valuable discussion!
Any guidance here would be helpful.  Without the ability to prompt the receptionist, at least give some hard guidance on these documents.  What is the best practices for a KB document? What will allow the AIR to relate items. Can it detect Bolded text? Hierarchies in a nested structure? Colors? XML? Tables?
I’ve had varied results as my team members add documents authored with different styles and structures and I need to give them a template to work out of. It seems like the receptionist trims anything > 35 words for instance.
Thank you for this valuable feedback. It really helps. I’ll raise this to our internal team so we can get the exact best-practice recommendations and share it with you.
Thanks again!
