Moving AI Summary and Transcriptions to a Customer Management System
  • April 16, 2025
  • 430 views
BHiggins
We noticed recently that RingCentral AI assistant can transcribe and summarizes calls. Is there a way to those summaries into our Customer Relationship Management system?
Steps/ Workarounds attempted:
(According to talking to tech/dev support and personal tests with APIs)
  1. AI assistant data cannot be accessed via API which means any movement would be extremely manual.
  2. RingSense (including at additional cost) has a very limited integration currently only containing a handful of Microsoft products none of which are a CRM.
  3. RingSense API (beta) cannot be used on RingCentral’s media URLs because the RingSense API can only be used on “publicly accessible url.” This could be used if we moved our RingCentral media URL’s to a publicly accessible URL but then it would mean that all our call data would be publicly accessible.
Do you know how we can get call summarizes into a CRM?
Lariane
  • March 16, 2026
Hi @BHiggins ,
If you are using RingCX together with RingSense, there is currently a way for summaries and transcripts to flow into a CRM when using the Salesforce integration.
When agents are working inside the Salesforce integration, the workflow works roughly like this:
  • The agent links the call to a case record in Salesforce during or after the interaction
  • The call transcription is automatically uploaded to that case record
  • This gives good visibility directly within the CRM without requiring manual export or API workarounds
One important caveat is that this only works when the agent is operating within the Salesforce integration itself. If agents are taking calls through the RingCentral Desktop App, Engage Digital (engage.ringcentral.com), or other interfaces outside of Salesforce, the automatic transcript upload to the case record does not occur.
From an operational perspective this part works quite well. The transcript appearing directly on the case record is very useful for case review, QA and internal collaboration.
However, one thing to be aware of is the quality of the AI call summary itself. In my experience the summary can be somewhat inconsistent. It often appears to focus heavily on the first ~30 seconds of the call, which means it can sometimes miss the main issue or resolution discussed later in the conversation. In some cases the summary doesn’t fully capture the outcome or key customer concern.
So in short:
What works well
  • Automatic transcription upload to the Salesforce case
  • No manual transfer needed when the call is properly linked
Where it still needs improvement
  • The AI-generated summary quality, which can sometimes miss the core context of the call
If your goal is simply to get conversation data into the CRM, the Salesforce integration already supports that workflow today. If you are looking for more reliable summarisation or broader CRM support, that’s definitely an area where the platform still has room to evolve.
Curious to hear if others have seen similar behaviour with the summaries or found ways to improve their usefulness.
