How to replicate call monitoring setup in RingCX?
  • May 15, 2025
  • 7 replies
  • 555 views
I have call monitoring implemented using call monitoring API in RingEx, now I want to implement the same for a RingCX system. What API’s should be used?
  • May 15, 2025
I don’t think that it’s supported via API in RingCX. You can post your request to the Ideals Portal for other developers/users to vote.
  • May 15, 2025
Any way apart from API’s to get recordings in real time?
  • May 15, 2025
@kutbuddin there are APIs under review that will stream audio in real time to a server, but there are several nuances to using the API and knowledge about protocols, stream buffers and codecs. It should be publicly available in the next couple of months.
  • May 16, 2025
  • May 16, 2025
Yes, if you are one of the beta customers and on a specific server. But very few customers have access to it right now.
  • May 16, 2025
  • May 16, 2025
Hi ​@z0lo, the link you posted is for RingEX, but this discussion is about RingCX. Thanks for trying to contribute though!
