Jun 3, 2020 2:33 PM UTC
active-calls and voIP
The active-calls API has a type field and the only options are Voice and Fax. I am missing calls that are voIP. Is there a way to retrieve these calls with this API?
    Jun 3, 2020 5:44 PM UTC
    Voice is all types of voice call and include VoIP calls. Here is a sample of an active call object of VoIP call
    { uri:
      ��'https://platform.ringcentral.com/restapi/v1.0/account/80964xxx/extension/59586xxx/call-log/IqYwk92ibFUjzUQ?view=Detailed',
      sessionId: '41888286xxx',
      startTime: '2020-06-03T17:38:00.000Z',
      type: 'Voice',
      direction: 'Inbound',
      action: 'Phone Call',
      result: 'In Progress',
      to:
       { name: 'Agent 120',
         phoneNumber: '+1209248xxxx',
       { name: 'Me myself',
         phoneNumber: '+1650513xxx,
      extension:
       { uri:
          'https://platform.ringcentral.com/restapi/v1.0/account/80964xxxx/extension/59586xxxx',
      telephonySessionId: 's-87d5abccda974e6c9e5923...',
      legs:
       [ { startTime: '2020-06-03T17:38:00.000Z',
           type: 'Voice',
           to: [Object],
           extension: [Object],
           legType: 'Accept',
           master: true },
         { startTime: '2020-06-03T17:38:04.000Z',
           type: 'Voice',
           direction: 'Outbound',
           action: 'VoIP Call',
           to: [Object],
           reason: 'Accepted',
           reasonDescription: 'The call connected to and was accepted by this number.',
           legType: 'PstnToSip',
           master: false } ] }
    Oct 4, 2021 2:40 AM UTC
    Where were the calls originally placed?
    Oct 4, 2021 2:17 PM UTC
    The call was from a PSTN number (mobile number) to a RingCentral number. You can see the legType is 'PstnToSip'
