Apr 22, 2024 11:31 PM UTC
Avg Speed of Answer
I need to include the average speed of answer in the Power BI Dashboard, and I'm using the Analytics API to pull data. Could you provide me with the formula for calculating the average speed of answer?
    Apr 24, 2024 9:02 PM UTC
    Can you set and check the callSegmentsDuration result.
