Feb 17, 2022 9:30 PM UTC
Basic C# example not working.
Hello, first time user here. I'm trying to test the most basic code sample for C# but it isn't working and it's throwing a very vague exception. Code and exception below. I replaced the sensitive variables with comments describing what they had been set to.
using System;
using System.Threading.Tasks;
using RingCentral;
using DotNetEnv;
namespace Call_Ringout
    class Program
        static RestClient restClient;
            restClient = new RestClient(
                /*Client ID*/,
                /*Client Secret*/,
                "https://platform.devtest.ringcentral.com");
            restClient.Authorize(
                /*Username*/,
                /*Extension*/,
                /*Password*/;
            call_ringout().Wait();
        static private async Task call_ringout()
            var parameters = new MakeRingOutRequest();
            parameters.from = new MakeRingOutCallerInfoRequestFrom
                phoneNumber = /*From Number*/
            parameters.to = new MakeRingOutCallerInfoRequestTo
                phoneNumber = /*To Number*/
            parameters.callerId = new MakeRingOutCallerInfoRequestTo
                phoneNumber = /From Number/
            parameters.country = new MakeRingOutCoutryInfo
                id = "1"
            parameters.playPrompt = false;
            //var resp = await restClient.Restapi().Account().Extension().RingOut().Post(parameters);
            //Console.WriteLine("Call Placed. Call status" + resp.status.callStatus);
            var _1 = restClient.Restapi();
            var _2 = _1.Account();
            var _3 = _2.Extension();
            var _4 = _3.RingOut();
            try
                var resp = await _4.Post(parameters);
            catch(Exception e)
                Console.WriteLine(e.InnerException);
                Console.WriteLine(e.Message);
                Console.WriteLine(e.ToString());
I broke up the line
Into its component parts to see where the problem is. It is in the last part, which is why I put the try block around it alone.
Here is the error I'm getting:
Object reference not set to an instance of an object.
System.NullReferenceException: Object reference not set to an instance of an object.
   at RingCentral.RestClient.Request(HttpRequestMessage httpRequestMessage, Int32 retriedTimes, Nullable`1 cancellationToken)
   at RingCentral.RestClient.Request(HttpMethod httpMethod, String endpoint, Object content, Object queryParams, Nullable`1 cancellationToken)
   at RingCentral.RestClient.Request[T](HttpMethod httpMethod, String endpoint, Object content, Object queryParams, Nullable`1 cancellationToken)
   at RingCentral.RestClient.Post[T](String endpoint, Object content, Object queryParams, Nullable`1 cancellationToken)
   at RingCentral.Paths.Restapi.Account.Extension.RingOut.Index.Post(MakeRingOutRequest makeRingOutRequest, Nullable`1 cancellationToken)
   at Call_Ringout.Program.call_ringout() in C:Userswscheffeysource
eposCall_RingoutCall_RingoutProgram.cs:line 55
C:Program Filesdotnetdotnet.exe (process 28572) exited with code 0.
To automatically close the console when debugging stops, enable Tools->Options->Debugging->Automatically close the console when debugging stops.
Press any key to close this window . . .
Any help greatly appreciated.
    Participating Frequently
    Mar 28, 2024 1:51 PM UTC
    I am having the same issue when doing a calllog, has anybody found a solution to this ?
    Mar 28, 2024 2:38 PM UTC
    I don't see how you create the query params so I cannot say what could be wrong. But get the latest .NET SDK and try this code.
    using System;
    using System.IO;
    using System.Collections.Generic;
    using RingCentral;
    using Newtonsoft.Json
    namespace Read_User_CallLog
      class Program
          try
            DotEnv.Load();
            // Instantiate the SDK
                    "RC_CLIENT_ID",
                    "RC_CLIENT_SECRET",
                    "RC_SERVER_URL");
            // Authenticate a user using a personal JWT token
            await restClient.Authorize( "RC_JWT" );
            await read_user_calllog();
          catch (Exception ex)
        * Read user call log between a period of time
        static private async Task read_user_calllog()
          try
            var queryParams = new ReadUserCallLogParameters();
            queryParams.dateFrom = "2024-01-01T00:00:00.000Z";
            queryParams.dateTo = "2024-01-31T23:59:59.009Z";
            queryParams.view = "Detailed";
            var resp = await restClient.Restapi().Account().Extension().CallLog().List(queryParams);
            foreach (CallLogRecord record in resp.records)
              Console.WriteLine(JsonConvert.SerializeObject(record, Formatting.Indented));
            Console.WriteLine("Cannot read user call log data. " + ex.Message);
    Mar 28, 2024 10:12 PM UTC
    using Newtonsoft.Json;
    using RingCentral;
    using System;
        class Program
            static async Task Main(string[] args)
                try
                    RestClient restClient = new RestClient(
                        "<myclientid>",
                        "<mysecret>",
                        "https://dummy.com"
                    // I have to use ConfigureAwait instead of wait cause it will
                    //just never return with wait.
                    restClient.Authorize("<MyJWT>").ConfigureAwait(false);
                try
    Thank you for replying. My code was in a .net API. I changed it to a console app but still getting the same issue, any help would be welcome.
    Mar 28, 2024 10:27 PM UTC
    You declared the static RestClient restClient in your class, then you declare a local restClient????
                        "<myclientid>",
                        "<mysecret>",
                        "https://dummy.com"
    Remove it!
                        "<myclientid>",
                        "<mysecret>",
                        "https://dummy.com"
    Mar 29, 2024 4:28 AM UTC
    I still get the same error message
    class Program
        static RestClient restClient = new RestClient(
              "<myclientid>",
                        "<mysecret>",
                        "https://dummy.com"
            try
            try
    Mar 29, 2024 2:28 PM UTC
    It's not the same error. Before, the restClient was null.
    What is the reason you call the authorize this way?
    Try this to see if it helps
    await restClient.Authorize("<MyJWT>"));
    Mar 29, 2024 4:31 PM UTC
    I changed everything to be await and I am now able to get records back, however it is only returning calls I have made. I am an admin on our account. Please help me with this.
     class Program
             "<myclientid>",
             "<mysecret>", true
             try
                 await restClient.Authorize("<MyJWT>");
                 var ringCallLogResponse = await read_user_calllog();
         static private async Task<CallLogResponse> read_user_calllog()
             CallLogResponse callLog = new CallLogResponse();
             try
                 callLog = await restClient.Restapi().Account().Extension().CallLog().List(queryParams);
                 foreach (CallLogRecord record in callLog.records)
             return callLog;
    Mar 29, 2024 4:34 PM UTC
    When I run it at https://developers.ringcentral.com/api-reference/Call-Log/readCompanyCallLog. I get back 99 pages with 100 records per page.
    Mar 29, 2024 4:46 PM UTC
    I removed the .Extension() and changed ReadUserCallLogParameters to ReadCompanyCallLogParameters and it works. Thank you for you help.
