Feb 9, 2021 11:01 PM UTC
Building and deploying without Maven or Gradle
Our use case prevents using Maven or Gradle as we have to deploy our Java class as an extension to another application. We need a stand-alone JAR to deploy and have not been able to utilize the JAR available via the SDK due to dependencies.
Is it possible to obtain a stand-alone JAR that includes all dependency libraries?
Feb 11, 2021 12:31 AM UTC
You can download jar file here https://bintray.com/tylerlong/maven/ringcentral/1.6.1#files/com/ringcentral/ringcentral
You need to download dependent libraries yourself: https://github.com/ringcentral/ringcentral-java/blob/master/build.gradle#L21-L22
We don't provide a standalone jar file which includes all dependencies. Because dependent libraries are not maintained by us, it is not a good idea to include other jar files inside ours.
Feb 11, 2021 8:35 PM UTC
We added the JARs manually, but it appears that the RingCentral JAR is dependent on the Kotlin JVM and we are unable to inject Kotlin into our runtime. We are deploying into an application that manages the JVM internally and does not allow for us to modify the JVM components.
Am I understanding how Kotlin is utilized in your SDK correctly? Do you have a version that is not Kotlin dependent?
Feb 17, 2021 10:50 PM UTC
Here is a working project https://github.com/tylerlong/ringcentral-jar-demo
You need to download and add the following jars to your project:
  1. // https://bintray.com/tylerlong/maven/ringcentral/1.6.1#files
  2. // https://bintray.com/bintray/jcenter/org.jetbrains.kotlin%3Akotlin-stdlib/1.3.50#files
  3. // https://bintray.com/bintray/jcenter/com.google.code.gson%3Agson/2.8.6#files
  4. // https://bintray.com/bintray/jcenter/com.squareup.okhttp3%3Aokhttp/3.14.2#files
  5. // https://bintray.com/bintray/jcenter/com.squareup.okio%3Aokio/1.17.2#files
I don't think we need to hack the JVM. But we do need the kotlin-stdlib jar file. It's just a jar file like other jar files. So I don't think it would be an issue for you.
