Aug 7, 2020 3:52 PM UTC
C#: Resource for parameter [extensionId] is not found
I am trying to pull users presence data in C#
I was able to get the AccountId and the ExtensionId from here:
Here is my code:
using System;
using System.Threading.Tasks;
using RingCentral;
namespace Send_SMS
    class Program
        const string RINGCENTRAL_CLIENTID = "<>";
        const string RINGCENTRAL_CLIENTSECRET = "<>";
        const string RINGCENTRAL_USERNAME = "<>";
        const string RINGCENTRAL_PASSWORD = "<>";
        const string RINGCENTRAL_EXTENSION = "<>";
        const string RINGCENTRAL_PRESENCE_USER = "<>";
        const string RINGCENTRAL_PRESENCE_EXT = "101";
        static RestClient restClient;
            restClient = new RestClient(RINGCENTRAL_CLIENTID, RINGCENTRAL_CLIENTSECRET, false);
            restClient.Authorize(RINGCENTRAL_USERNAME, RINGCENTRAL_EXTENSION, RINGCENTRAL_PASSWORD).Wait();
            get_presence().Wait();
        static private async Task get_presence()
            // OPTIONAL QUERY PARAMETERS
            ReadUserPresenceStatusParameters readUserPresenceStatusParameters = new ReadUserPresenceStatusParameters
                //detailedTelephonyState = true,
                //sipData = true
            var response = await restClient.Restapi().Account(RINGCENTRAL_PRESENCE_USER).Extension(RINGCENTRAL_PRESENCE_EXT).Presence().Get(readUserPresenceStatusParameters);
            Console.WriteLine("Presence for Test Account: " + response.presenceStatus);
Everything in <> is filled out of course, and tested with the SMS_Send tutorial.
My error:
Content: {"errorCode":"CMN-102","message":"Resource for parameter [extensionId] is not found","errors":[{"errorCode":"CMN-102","message":"Resource for parameter [extensionId] is not found","parameterName":"extensionId"}],"parameterName":"extensionId"}
Thanks in advance. I'm really struggling to understand the account/extension side of this API.
    Aug 7, 2020 4:28 PM UTC
    This is because you are not giving correct extension id number. You can get all the id numbers for all your extensions with this API
    GET https://platform.devtest.ringcentral.com/restapi/v1.0/account/~/extension/~
    It will return response with account id number and extension id number. example:
    "uri": "https://platform.devtest.ringcentral.com/restapi/v1.0/account/123456789/extension/987654321",
    account id number will be 123456789 and extension id number will be 987654321
