Aug 23, 2024 5:59 AM UTC
Call monitoring with Ringcentral + Incontact possible?
Are the call monitoring api’s available for systems where Ringcentral + Incontact is used as a combined offerring?
Aug 23, 2024 3:11 PM UTC
Call monitoring API is only for RingEX platform.
kutbuddinThe First StepAuthor
Aug 26, 2024 12:21 PM UTC
Should have been more specific here. Should I assume this will be true for RingEx + Incontact?
Aug 26, 2024 2:46 PM UTC
I don’t understand what you meant “+ Incontact”.
If you have a RingEX account and you have user(s) and phone number(s) under that account, you can setup call monitoring group and monitor those user calls using the call monitoring API.
Maybe you should consult with your RingCentral account manager about call supervision feature on your account to see if it’s possible at all before looking into the call monitoring API.
Participating Frequently
Aug 26, 2024 3:53 PM UTC
Good morning, @kutbuddin .
Call monitoring (Whisper, Barge, Take over), is available on both RingEx (Advanced/Ultra) at no additional cost. And likewise for Incontact.
https://support.ringcentral.com/article-v2/Monitoring-live-calls-in-the-RingCentral-app.html?brand=RingCentral&product=RingEX&language=en_US
Aug 27, 2024 3:17 AM UTC
I will explain the setup. Incontact handles all the call center operations, it depends on RingCentral for managing the audio part of the calls.
we had initiated contact with a Ringcentral account manager and he mentioned RingCentral apis are only for the UC side of the house. Not for the contact center.
Which led to the confusion if RingEx(Professional) was being used to handle the audio telephony with the Incontact contact center solution will the call monitoring api’s work or not.
Aug 27, 2024 8:45 PM UTC
In that case I am not sure about the settings.
The basic requirements from RingEX side is that both supervisor and the monitored agents need to be under the RingEX side. And the calls must be handled by the telephony server so that we can get the telephony session id and the call party id which is required by the call monitoring API.
I suggest you open a dev support ticket so some one can have a look at the account settings and tell you more.
