Dec 11, 2017 2:22 PM UTC
Create webhook for receiving calls using Javascript sdk
HI all try create webhook for receiving calls using javascript sdk, but i got Error: Parameter [request] value is invalid
This is my following code
 var _eventFilters = [];
        _eventFilters.push('/restapi/v1.0/account/~/extension/' + 101 + '/presence?detailedTelephonyState=true&aggregated=true')
  rcsdk.platform()
            .send({
                method: 'POST',                  url: '/subscription',                  eventFilters: _eventFilters,                  deliveryMode: {                      "transportType": "WebHook",                      "encryption": false,                      "address": "https://33d7f758.ngrok.io/RingCentralTest/RcTest";                  }              })              .then(function (apiResponse) {                  console.log(apiResponse.json())                })              .catch(function (e) {                    console.log(e)              });
Thanks in Advance
Dec 11, 2017 7:27 PM UTC
Hi Robert,
The event filters that you have passed for creating the subscription via WebHook is wrong.
Kindly use the below code and try the API call again:
        _eventFilters.push('/restapi/v1.0/account/~/extension/~/presence?detailedTelephonyState=true&aggregated=true')
When you pass the event filters for an extension you can either provide :
1.) (~) which would refer to the extension authorized by.
2.) Provide the extensionID for an extension, which you can look up using the below API Endpoint
      Get Extensions List
      GET /v1.0/account/{accountId}/extension/
Dec 11, 2017 11:35 PM UTC
101 is extension number. Extension ID is expected.
Dec 12, 2017 5:33 AM UTC
After applying the extension id getting the error
    at Client.<anonymous> (/var/www/html/commusoft-app/node_modules/ringcentral/src/http/Client.js:62)
    at <anonymous>
