Jul 9, 2018 8:53 AM UTC
embeddable voice with multi tenant crm
Trying to integrate embeddable voice with a multi tenant CRM application. Since wildcard URLs aren't permitted as redirect URIs, I'm not sure how to proceed further.
Jul 9, 2018 8:59 AM UTC
Hi, Thujeevan. Can you show more detail information about how you use it and what you want it to perform. So we can provide correct solution.
Jul 9, 2018 9:08 AM UTC
Hi Embbnux, thanks for getting back so quickly.
Our CRM application offered in a multi tenant way. For eg. tenant1.salpo.com, tenant2.salpo.com. Hence each instance should have a separate redirect URI to be identified uniquely. But in RC developer console, a client app can't have wildcard domain as a redirect URI. So I'm trying to find a way to integrate with such applications.
Hope you understand the problem. Any leads to the solution would be much appreciated.
Jul 9, 2018 9:13 AM UTC
Hi, Thujeevan. A RingCentral app can add 10 different redirect uri in developer website. If you want more, you need to create different apps.
Jul 9, 2018 9:16 AM UTC
Unfortunately, that wouldn't be the right approach I suppose. Tenants would be numerous and increasing.
Jul 9, 2018 9:18 AM UTC
Let me check with my colleagues to find a good way
Jul 10, 2018 2:26 AM UTC
Hi, are you using redirect uri to get access token and request data from RingCentral API. Can you just use default redirect uri and get data from the widget.
