Dec 6, 2023 1:22 AM UTC
Getting "CMN-102 Resource for parameter [deviceId] is not found" when trying to make callout using c# sdk
I am using JWT Authentication and when I try to create a callout request, I am getting Resource for parameter [deviceId] is not found. Can someone point out what I am missing here?
Little more context: In production, we have 9 Lines and we need to perform callout from those lines in parallel. For now, I am just trying to build a POC with one line. Device is Online and is hardphone.
Code looks like this:
var restClient = new RestClient("CLIENTID", "CLIENTSECRET", true); //Have
await restClient.Authorize("JWT TOKEN");
var parameters = new MakeCallOutRequest
    from = new MakeCallOutCallerInfoRequestFrom { deviceId = "device_id" }, //Line 5 device id
    to = new MakeCallOutCallerInfoRequestTo { phoneNumber = "PHONE TO CALL" }
var resp = await restClient.Restapi().Account().Telephony().CallOut().Post(parameters); //getting error here
Dec 6, 2023 4:09 PM UTC
In this case, you should open a dev support ticket, provide the info and the support team can have a look at your code or account/device settings.
