Feb 14, 2017 2:35 PM UTC
Graduation SubscriptionWebhook permission status is always in red after running running nodejs sample
I cloned and run as per docs
Graduation permission SubscriptionWebhook is in red only
> ringcentral-subscription-basics>npm start> ringcentral-subscriptions@0.2.0 start C:xampphtdocs c ingcentral-subscription-basics
> node index.js
Succesfully logged into the RC Account
EVENT FILTERS: [ '/account/~/extension/664597005' ]
SUBSCRIPTION CREATED SUCCESSFULLY
Found Your Voice
Feb 14, 2017 4:39 PM UTC
Would you please post this question on the Github Issue tracker for the repository: https://github.com/bdeanindy/ringcentral-webhook-basics/issues
In your question, could you please include the settings for your application:
- Platform Type
- Scope
- Application Type
- API Permissions
- Redirect URI
Lastly, could you please include a screenshot of the "Status & Review" page of your application from the RingCentral Developer Portal (which you are referencing as "showing red") as part of your question on the Github issue tracker?
Feb 14, 2017 6:21 PM UTC
Feb 15, 2017 3:35 AM UTC
I assume it should be fixed now. Can you recheck?
