Dec 19, 2023 1:34 PM UTC
Handling Call Transfers and Sessions with SessionId of 0
Good day all,
My company has an integration with RC where we receive call data via telephony webhook and process that data on behalf of our customers. I have two questions:
1. Our code does not properly handle transferred/ multi-leg calls. I have been doing some research and believe I can tell a call has been transferred by the presence of an event with the status code of "Gone". Is it accurate to say this event represent the start of a new leg of the call? Additionally, I noticed that a "Gone" event can have the following reasons: "Pickup", "Undefined", "AttendedTransfer", "Conference", "Supervising". Would you kindly briefly explain these reasons?
2. One other thing I noticed in our data is that we receive calls with a session id of 0. Specifically, I am noticing these calls have to do with conferencing. Is there any other reason why a session would have a sessionid of 0 other than conferencing? See below example of transfer to conference with peer id.sessionid of 0.
"code": "Gone",
"reason": "Conference",
"peerId": {
"telephonySessionId": "s-a0dd888305b18z18c590772c3z13204cb0000",
"sessionId": "0",
"partyId": "p-a0dd888305b18z18c590772c3z13204cb0000-2"
Dec 19, 2023 4:56 PM UTC
1.
- "Gone" - "AttendedTransfer" => A call is warm transferred. The original call is gone
- "Gone" - "Supervising" => A supervising call leg is established
- "Gone" - "Conference" => A call is merged to a 3-way conference call. The original 2-way call is gone.
I am not aware of the "Gone" - "Pickup" and "Undefined" though.
2. A 3-way conference call made by the RC app is a bridge call. It has the origin type
 "origin": {
        "type": "Conference"
And it has the sessionId=0. The conference (bridge) call has the telephonySessionId and it is referenced in the peerId object.
"peerId": {
    "sessionId": "0",
acahillThe First StepAuthor
Dec 19, 2023 5:15 PM UTC
Phong,
thank you so very much for your prompt reply! Two follow up questions. When you say the original call is gone, we can still construct the original call using the previous events in the session, correct? For example, a call takes place as normal however, event 8 of the session is Gone (Attended Transfer), we can still construct the original call with events 1-7, correct? When we detect a transfer, how can we tell the new numbers involved in the call? For example, if 404-809-6345 calls 104 and then gets transfered to 106, how can we tell from the event the new number involved in the call? I see on a transfer, the peerId object has a new session id, will that new session be sent to us via webhook with the next leg of the call? Hopefully that makes sense.
