Jun 24, 2021 4:23 AM UTC
How to create post with attachments in a glip team using NodeJS Javascript SDK?
Hi Guys!
I'm trying to create a post with attachments using this Create Post api endpoint in the javascript SDK in NodeJS, but I can't seem to get it working. The endpoint looks like it only accepts attachment Ids but not sure where/how to get them as the files are not uploaded yet.
I tried using the same approach as the this create fax message endpoint but with no luck. I just get 'Error 415 Unsupported Media Type' and I'm trying to upload a PDF file which should be a standard accepted file type as I can upload it directly in Glip. BTW, at the moment I'm doing this in the sandbox, not sure if that is important.
Please any help to point me in the right direction would be much appreciated. If there is any more information that you guys need and think that may help please ask.
Thanks in advance.
Create Post API Endpoint: https://platform.devtest.ringcentral.com/restapi/v1.0/glip/chats/chatId/posts
PhongVuAnswer
Jun 25, 2021 7:12 PM UTC
Here is some snippet code
// Read your chat or team to get a chat or team id
async function get_glip_chat(){
  try{
    var endpoint = "/restapi/v1.0/glip/chats"
    var resp = await platform.get(endpoint)
    var json = await resp.json()
    for (var record of json.records){
      console.log("Chat name: " + record.name)
      console.log("Chat id: " + record.id)
      if (record.name == "A Chat Name"){
        uploadFile(record.id)
        break
  }catch(e){
    console.log(e)
// upload your file
async function uploadFile(groupId){
  var endpoint = `/restapi/v1.0/glip/files?name=test.jpg&groupId=${groupId}`
  var FormData = require('form-data');
  formData = new FormData();
  formData.append('attachment', require('fs').createReadStream('test.jpg'));
  try {
    var resp = await platform.post(endpoint, formData)
    postAttachment(groupId, jsonObj[0].id)
  }catch(e){
    console.log(e)
// post text and attachment
function postAttachment(groupId, attachmentId){
  var endpoint = `/restapi/v1.0/glip/chats/${groupId}/posts`
  var params = {
    "text": "Hello there. My first image file",
    "attachments": [ {
      "id": attachmentId,
      "type": "File"
  platform.post(endpoint, params)
    .then(function(resp){
        var json = resp.json()
    .catch(function(e){
        console.log(e)
The known issue is that you will see 2 posts, one with just an attachment and the second one with text and attachment.
PhongVuAnswer
  try{
        break
  }catch(e){
    console.log(e)
// upload your file
  try {
  }catch(e){
    console.log(e)
  var params = {
    "attachments": [ {
      "id": attachmentId,
      "type": "File"
    .catch(function(e){
        console.log(e)
nmontrondThe First StepAuthor
Jun 29, 2021 12:22 AM UTC
Thank you very much Phong! This was very helpful!
We were able to upload the attachment, the only weird behavior that we saw is that just by uploading a file, it showed up in the team as a post. We didn't have to create a post after uploading the file and then reference the attachment id. This is fine when the attachment doesn't have a text (the user didn't write a message when sending the attachment) but when there is a message/text and we create that post with the text/message and reference the attachmentID, then the file shows up on 2 posts (one without the message and one with the message). Is there somehow we can hide the post created when uploading a file?
Jun 29, 2021 12:23 AM UTC
Jun 29, 2021 12:26 AM UTC
Sorry, I didn't notice that you pointed out that known issue. Any ideas on how to solve that?
