May 15, 2025 5:01 AM UTC
How to replicate call monitoring setup in RingCX?
I have call monitoring implemented using call monitoring API in RingEx, now I want to implement the same for a RingCX system. What API’s should be used?
    May 15, 2025 2:31 PM UTC
    I don’t think that it’s supported via API in RingCX. You can post your request to the Ideals Portal for other developers/users to vote.
    kutbuddinThe First StepAuthor
    May 15, 2025 4:08 PM UTC
    Any way apart from API’s to get recordings in real time?
    May 15, 2025 8:35 PM UTC
    ​@kutbuddin there are APIs under review that will stream audio in real time to a server, but there are several nuances to using the API and knowledge about protocols, stream buffers and codecs. It should be publicly available in the next couple of months.
    May 16, 2025 8:48 AM UTC
    May 16, 2025 2:40 PM UTC
    Yes, if you are one of the beta customers and on a specific server. But very few customers have access to it right now.
    May 16, 2025 11:00 PM UTC
    Hi ​@z0lo, the link you posted is for RingEX, but this discussion is about RingCX. Thanks for trying to contribute though!
