Dec 9, 2020 5:56 PM UTC
Identify incoming call party details from telephony session webhook
How to filter out or identify only the incoming calls to a particular extension from Telephony Session webhook. I need to identify it before it ring to the dialled extension(reception extension). Then I will route the call to other extension depending on on my custom logic, with out ringing that reception extension phone.
I have used active call list, but it ring the extension before gets routed to other extension. Can you guide me how can I achieve the expected outcome?
Thank you.
    Dec 10, 2020 12:12 AM UTC
    Read this blog and pay attention to the "Call statuses and how to use them" section. You can take action as soon as you get the "Setup" status event.
