Jan 30, 2025 8:25 AM UTC
Inconsistent Telephony Sessions Extension Events Schema
[{'type': 'ServerNotification', 'messageId': 'xxxxxx', 'status': 200, 'headers': {'RCRequestId': 'xxxxxxx'}}, {'uuid': 'xxxxx', 'event': '/restapi/v1.0/account/xxxxxx/extension/xxxxxx/telephony/sessions', 'timestamp': '2025-01-29T14:17:14.428Z', 'subscriptionId': 'xxxxxx-xxxx-xxxx-a9f4-xxxxxx', 'ownerId': '63047761004', 'body': {'sequence': 3, 'sessionId': 'xxxxxx', 'telephonySessionId': 's-xxxxx', 'serverId': '10.13.121.172.TAM', 'eventTime': '2025-01-29T14:17:14.308Z', 'parties': [{'accountId': 'xxxxx', 'extensionId': 'xxxx', 'id': 'p-xxxxx-1', 'direction': 'Outbound', 'to': {'phoneNumber': '+xxxxxx'}, 'from': {'phoneNumber': '+xxxxxx', 'name': 'xxx xxxx', 'extensionId': 'xxxxx', 'deviceId': 'xx'}, 'status': {'code': 'Answered', 'rcc': False}, 'park': {}, 'missedCall': False, 'standAlone': False, 'muted': False}], 'origin': {'type': 'CallOut'}}}]
Another event with the same status but recordings field added
[{'type': 'ServerNotification', 'messageId': 'xxxx', 'status': 200, 'headers': {'RCRequestId': 'xxxx'}}, {'uuid': 'xxxx', 'event': '/restapi/v1.0/account/xxxx/extension/xxxx/telephony/sessions', 'timestamp': '2025-01-29T14:17:24.135Z', 'subscriptionId': '1f528df6-xxx-4dbe-xxx-xxxxxx', 'ownerId': 'xxxx', 'body': {'sequence': 7, 'sessionId': 'xxxxx', 'telephonySessionId': 'xxxxxx', 'serverId': '10.13.121.172.TAM', 'eventTime': '2025-01-29T14:17:24.063Z', 'parties': [{'accountId': 'xxx', 'extensionId': 'xxx', 'id': 'p-xxxx-1', 'direction': 'Outbound', 'to': {'phoneNumber': '+xxxx'}, 'from': {'phoneNumber': '+xxxxx', 'name': 'xxx xxxx', 'extensionId': 'xxx', 'deviceId': 'xxxx'}, 'recordings': [{'id': 'xxxxxx', 'active': True}], 'status': {'code': 'Answered', 'rcc': False}, 'park': {}, 'missedCall': False, 'standAlone': False, 'muted': False}], 'origin': {'type': 'CallOut'}}}]
Where can I see the event structures or different event types which can help me handle such status accordingly?
Jan 30, 2025 3:29 PM UTC
The first event with the status.code:”Answered” without the ‘recordings’ object is the event when the call is answered. Then you will get more events with the same status.code:”Answered” with the ‘recordings’ object when the call recording started (active:True), paused (active:False), resumed (active:True) or stopped (active:False).
So if you only need to identified when the call is answered, grab the first “Answered” event, get the timestamp or any data you need, and ignore other subsequent events with the “Answered” status and the ‘recordings’ object.
kutbuddinThe First StepAuthor
Jan 31, 2025 12:26 PM UTC
Thanks for answering ​@PhongVu  Do you have any opinion on this as well:
Jan 31, 2025 3:38 PM UTC
Answered in the other thread. not sure why I missed that question :).
