May 11, 2025 6:14 AM UTC
Is there a limit for making more than 5 simultaneously calls using ringcentral-softphone-ts from a single number ?
Hi folks!
I’ve tried to make 5 calls using https://github.com/ringcentral/ringcentral-softphone-ts from a single number at the same, it worked very well, but when I add 1 more, I didn’t receive any message from TLS connection.
Is there any limit or something there ?
May 12, 2025 4:30 PM UTC
It is an known limitation. And it is a server side limitation, not specific to the softphone SDK. No matter what SDK/client app you are using, you can have no more than 5 active calls.
