Jul 31, 2019 8:21 PM UTC
Java sdk guide
I have been using ringcentral various apis specially create sms/mms api for send messages.
However, instead of using directly with the api, I know want to use the feature in java. I know ringcentral has support with various programming languages, but I am looking to start this feature in java program.
Do I need to use Java rest client to call this create sms api in java or it has a different way of doing it in java? Any pointer to get start with in java language is appreciated
Jul 31, 2019 8:40 PM UTC
RingCentral do has various SDK for different programming languages. Official RingCentral ofJava SDK: https://github.com/ringcentral/ringcentral-java
You can check the sample of sending sms to start with:
https://github.com/ringcentral/ringcentral-java/blob/master/samples.md#create-smsmms-message
