Apr 7, 2022 4:00 AM UTC
JWT authorization does not work, error OAU-250 "unsupported grant type"
Using JWT to request an access token as explained at https://developers.ringcentral.com/guide/authentication/jwt-flow#technical-discussion does not work. I created an application in Sandbox with "Read Accounts" permissions and a JWT for "all apps belonging to my organization" and followed the instructions in the documentation above. When I POST to https://platform.devtest.ringcentral.com/restapi/oauth/token as shown in the example, I get 400 invalid request and errorCode OAU-250 "Unsupported grant type". I have tried it with both Postman and curl and get the same error. I have properly base64-encoded the Client ID and Secret with a ":" between them (I've done this with other APIs on other platforms and know the routine). I added the Content-Type as shown in the example, added the JWT to the body, etc. I've deleted and regenerated the JWT numerous times as well as the applications. It does not work. Is the JWT authorization flow one that we can actually use? Or is it reserved from some special, unnamed APIs or authorization servers? It doesn't work in the Sandbox.
    laurenraAnswer
    Apr 12, 2022 11:13 PM UTC
    Thank you Phong, Yatin and Suyash. Those examples all worked. The problem wasn't public or private. The problem I had was that I didn't URL encode the grant_type and assertion. I was sending (wrong):
    grant_type=urn:ietf:params:oauth:grant-type:jwt-bearer
    instead of (right):
    grant_type=urn%3Aietf%3Aparams%3Aoauth%3Agrant-type%3Ajwt-bearer
    And when I ran it in Postman, I also incorrectly set the Body to use "form-data" instead of "x-www-form-urlencoded" (which URL encodes the value for grant_type and assertion). Thank you for the excellent responses.
    laurenraThe First StepAuthor
    Apr 7, 2022 4:13 AM UTC
    And yes, when I created the app, I marked "JWT auth flow" instead of "3-legged OAuth flow authorization code".
    Apr 7, 2022 2:51 PM UTC
    The problem is that you created a public app "All APIs JWT Test" and you select the "Personal JWT". I change your app scope to "Private" now. Try it again.
    Apr 8, 2022 10:30 PM UTC
    Hi @Lauren Anderson here is a sample project on GitHub that you can clone/download and run it. Just make sure to update the .env file with your credentials including JWT and it should work: https://github.com/suyashjoshi/ringcentral-node-auth-jwt
    laurenraThe First StepAuthorAnswer
    instead of (right):
    Apr 13, 2022 7:02 PM UTC
    glad you figured it out!
