Oct 20, 2023 5:19 PM UTC
JWT: error Error: Client authentication is required | Node SDK
Using this code to try and authenticate the SDK.
import { SDK } from "@ringcentral/sdk";
export default async function fetchRingCentralData() {
  const rcsdk = new SDK({
    server: process.env.RC_SERVER,
    appKey: process.env.RC_CLIENTID,
    appSecret: process.env.RC_CLIENTSECRET,
  const platform = rcsdk.platform();
  await platform.login({ jwt: process.env.RC_JWT });
Receiving error
The app is set up as a JWT app.
Can someone help?
PhongVuAnswer
Oct 20, 2023 7:33 PM UTC
The new SDK constructor takes new param object.
    clientId: process.env.RC_CLIENTID,
    clientSecret: process.env.RC_CLIENTSECRET,
Can you share the link to the documentation or sample code that shows you the old code. We will fix the documentation accordingly. Thanks.
PhongVuAnswer
nargyleThe First StepAuthor
Oct 20, 2023 9:36 PM UTC
That worked, thank you. I probably pulled that from some other community post's code when debugging something else. Could've sworn I tested what was in the docs, but apparently not. Docs all appear correct.
Oct 20, 2023 9:40 PM UTC
