Apr 20, 2021 1:36 PM UTC
.NET SDK OAuth issue - why can I not get a token?
Hello,
We use RingCentral.Net SDK and have difficulties getting a token. RestClient’s Authorize method is not working properly. It returned result’s status is “WaitingForActivation”. The Client token result is null.
Also is there any way to use rc_credential.json file to pass OAuth?
Apr 20, 2021 2:23 PM UTC
Hi, thank you for the answer, we have already tried all your mentioned solutions, but unfortunately, it didn't give any result.
Apr 20, 2021 6:55 PM UTC
I believe it is a C# programming issue. Did you "await" ?
