local728
oau-250 Error with JWT authentication flow
I am getting the OAU-250 error when attempting the JWT Authentication Flow. I am basically using CURL to attempt this. The curl options are:
"–X POST -D \"\" --header \"Accept: application/json\" --header \"Content-Type: application/x-www-form-urlencoded\" --header \"Authorization: Basic " & $basic  & "\" --data " & $data
$basic is a base64 encoded combo of clientID:clientSecret
$data is "grant_type=urn%3Aietf%3Aparams%3Aoauth%3Agrant-type%3Ajwt-bearer&assertion=" & $jwt
$jwt is the jwt value we received in the rc_credentials.json file for the application.
The app is private and is configured for JWT auth flow and issue refresh tokens is set to Yes. The application scope is set to read accounts and ringout.
What am I missing?
local728
local728Answer
It worked on the Mac, so I researched the differences of curl on a Mac and Windows and found the solution. On a Mac/Linux machine. you enclose the parameters with ‘. On a Windows machine, you enclose the parameters with “. Also of note on Windows, if you run from PowerShell, curl is now aliased to Invoke-WebRequest, so if you want to use curl, you need to call curl.exe. Hope this post helps save someone else a lot of time :-)
So in the end, the command, on Windows needs to be:
curl -request POST
--header "Accept: application/json"
--header "Content-Type: application/x-www-form-urlencoded"
--header "Authorization: Basic XYZABC=="
--data "grant_type=urn%3Aietf%3Aparams%3Aoauth%3Agrant-type%3Ajwt-bearer&assertion=eXYZABZQ"
--url "https://platform.ringcentral.com/restapi/oauth/token"
I am now working :-)
Replace the based64 encoded and the JWT token and try this form of curl
curl --request POST \
--url 'https://platform.ringcentral.com/restapi/oauth/token' \
--header 'Accept: application/json' \
--header 'Content-Type: application/x-www-form-urlencoded' \
--header 'Authorization: Basic [based64 encoded clientId:clientSecret]' \
--data 'grant_type=urn%3Aietf%3Aparams%3Aoauth%3Agrant-type%3Ajwt-bearer&assertion=[YourJWTToken]'
local728
local728Author
Same result.
{  "error" : "invalid_request",  "error_description" : "Unsupported grant type",  "errors" : [ {    "errorCode" : "OAU-250",    "message" : "Unsupported grant type"  } ]}
Same result.
Then probably your app is not a JWT flow. What is the app client id?
local728
local728Author
3bE6qFKZ8PYejkchRxkiWD
JWT is clearly selected in the portal.
I use your app credentials and the JWT token and it works well
"access_token" : "U0pDMDFQMDZQQVM....",
"token_type" : "bearer",
"expires_in" : 3600,
"refresh_token" : "U0pDMDFQMDZQQVMwMHx....",
"refresh_token_expires_in" : 604800,
"scope" : "ReadAccounts RingOut",
"owner_id" : "319508XXXX",
"endpoint_id" : "X21JJSrFTaS47XRTUY...",
"session_id" : "875400b4-7db1-4b47-ad65-25785b04...",
"session_idle_timeout" : 3600
I see that you have 2 JWT tokens, one for a specific app and one for all apps under the account. Use the one for all apps to make sure that it allows you to authenticate any app, otherwise, use the right JWT token and the right app credentials.
If that does not help, double check your code, the based64 encoded etc.
local728
local728Author
Using the JWT ending in toQ
Using the client ID ending in WD
Using the secret ending in v4
Is the basic authentication literally Base64(xxxxxxxv4:XXXXXXXWD)? Do we keep the == in from the end of the command?
I ran the curl command from the command line and got the same error.
Every single char from the based60 encoded. So including the ==
local728
local728Author
That’s what I’m doing and still get the error.
If it does not work with the
Why did you put the string to be based64 encoded “clientSecret:clientId”?
It must be clientID:clientSecret. So it must be Base64(xxxxxxxWD:XXXXXXXv4)
local728
local728Author
Sorry, that was a typo. Checking the code it is (xxxxxxxWD:XXXXXXXXv4). That results in an encoded string staring with M2 and ending with NA==. I have done the conversion using multiple tools and get the same result.
